enable vlan
enable [ {vlan} vlan_name | vlan vlan_list]
Description
Use this command to re-enable a VLAN that you previously disabled.
Syntax Description
vlan_name Specifies the VLAN you want to enable.
vlan_list Specifies the VLAN list of IDs you want to enable.
Default
Enabled.
Usage Guidelines
This command allows you to administratively enable specified VLANs that you previously disabled.
The following example enables the VLAN named "accounting":
enable vlan accounting
This command was first available in ExtremeXOS 11.4.
The vlan_list option was added in ExtremeXOS 16.1.
Platform Availability
